- Oct 11, 2012
- Wisconsin
the stainless ones will not only be expensive but also will introduce mixed metals into your loop.
the temp range is waay better though.
sharkbite can handle the temps and there are a few other clones of the sharkbite.
those plastic ones are often found in newer water softeners.
Anything that can be hooked up to a domestic hot water supply should be fine temperature wise but you dont want to mix metals too much in a loop.
