- Jul 12, 2007
- Thread Starter
- #21
That's right, the core temp sensors are borked when the CPU is unlocked @ 6 cores.The image below does not show the CPU Core Temps but am guessing the Cpu Core Temps to be about 10c or so below the CPU Temp and that should be very good at 4.0Ghz with not too great of a Vcore applied. Looks like a pretty good overclock actually.
Core temps should be 15C degrees lower actually according to my CPU-locked load test @ 3.0Ghz:
That would make core temps in this case to be about 37C-40C.
It should also be similar when the CPU is locked @ 4 cores running the same temps.
Thank you!That is excellent! To be able to get to 4.0 ghz on that low of core voltage with all the cores unlocked is not common. You have a bit of a cherry CPU there I would say. I could not get mine stable on six cores past 3.9ghz without exceeding 1.5 vcore by a considerable amount.
Can I try to overclock the NB to 3000+mhz and RAM to 1700+mhz and tighten the timings before I see how far I can overclock at 4 cores? And any general tips on how to do this?What you should try now is to see how far you can overclock it as a four core. More than likely it will go higher than 4.0ghz as a four core and since few applications can take advantage of six cores anyway you might find that actually gives you better performance than running it at six cores. You would see that to be true in games, for instance where a higher clock speed will give better performance that more cores at a lower clock speed.
I want to be able to achieve this with perfect stability in Prime95 Blend for 24+ hours!
