- Dec 31, 2011
I just added second fan on my Hyper+ for push pull config. I was in local microcenter and grabbed this one as pwm Y cable http://www.microcenter.com/single_product_results.phtml?product_id=0341752
It works with Molex connector but I noticed that out of 3 male connectors only one has 4 pin and other 2 has only 3 male pins. And that makes one of my Hyper 212+ fan spins at full speed even when computer is idle.
When i had only one fan on Hyper 212+ it used to spin ard 800-1000 rpm and now second fan is spinning @ 2000 always.
So can anyone suggest me a Y cable (preferable exact link on newegg or amazon) that can split motherboard cpu 4 pin male connector to two 4 pin male connectors. I dont want either of these 2 fans on Hyper 212+ spin unnecessarily high speed.
PS: I looked around and found some results (most of them seems to have 3 pin female connectors) but want to make sure it works to my needs before putting order online.
thanks.
thanks.
