Hello,
I recently bought a Noctis 450 which comes with an integrated 8-port fan hub for PWM.
I'm currently looking for case fans, preferably with LED. I noticed that 4-pin are usually PWM and 3-pin are "static"...
How does this work ? The fan hub only accepts 3-pins...should I care if the fans are "static" and not 4-pins?
Sorry, don't know how to clearly describe my question.
For instance,
http://www.newegg.com/Product/Product.aspx?Item=N82E16835106327
http://www.newegg.com/Product/Product.aspx?Item=N82E16835553013
Would that benefit from PWM ?
Thanks in advance.
For instance,
Thanks in advance.
