naroslife
- Jun 14, 2015
Hello there!
I'm wondering which of the following deals do you find the best.
Is the last one a good water cooling set? Does it worth the extra money for the 240-X over the 220? I'm planning on expanding the loop with a GPU block in the future. I'm not sure if the H220's pump is strong enough for that though :/
Regards,
naroslife
Edit:
My PC build:
- Swiftech H240-X for ~214 USD
- Swiftech H220 (not the newer X version) for ~146 USD
- The following custom set for ~209 USD
- CPU Block: Phobya UC-2 LT Black Edition
- Pump: Phobya DC12-220
- Reservoir: Alphacool Cape corp 10LT
- Radiator: Alphacool NexXxus ST30 Full Copper 240mm
- Fans: 2 pcs Yate Loon D12SL-12
- Tubing: Masterkleer 10/8mm-es csomag
- Liquid: Aqutuning AT-Protect 0,5L
Regards,
naroslife
Edit:
My PC build:
- Case: Corsair Graphite 230T
- Motherboard: Gigabyte GA-Z97X-UD3H (IDK the revision, but can check if needed)
- Ram: Kingston HyperX Fury 2x4 GB Kit (DDR3)
- CPU: Intel Core i7-4790K
- GPU: Gigabyte R9 280 OC
- PSU: Corsair CS650M
- HDD: 1 TB Western Digital Blue
- SSD: 128 GB Samsung 850 Pro
- Extra fans: 1 piece of 120 mm Noctua NF-S12A FLX on the bottom
