q6600 over clocking for 4ghz club
Ekko
isnt of high jacking there thread i figured it made since to make my own..
this is my full si sandra system specs..
Code:
SiSoftware Sandra
System
Host Name : SIM-PC
User : sim
Workgroup : WORKGROUP
Processor
Model : Intel(R) Core(TM)2 Quad CPU    Q6600  @ 2.40GHz
Speed : 3.51GHz
Cores per Processor : 4 Unit(s)
Threads per Core : 1 Unit(s)
Type : Quad-Core
Internal Data Cache : 4x 32kB, Synchronous, Write-Thru, 8-way, 64 byte line size
L2 On-board Cache : 2x 4MB, ECC, Synchronous, ATC, 16-way, 64 byte line size, 2 threads sharing
System
System : System manufacturer P5K Deluxe
Mainboard : ASUSTeK Computer INC. P5K Deluxe
Bus(es) : ISA PCI PCIe IMB USB FireWire/1394 i2c/SMBus
Multi-Processor (MP) Support : No
Multi-Processor Advanced PIC (APIC) : Yes
System BIOS : American Megatrends Inc. 0902
Total Memory : 3.25GB DIMM DDR2 DDR3
Chipset
Model : ASUS P35/G33/G31 Processor to I/O Controller
Front Side Bus Speed : 4x 390MHz (1.56GHz)
Total Memory : 4GB DIMM DDR2 DDR3
Memory Bus Speed : 2x 488MHz (976MHz)
Memory Module(s)
Memory Module : Kingston KTC1G-UDIMM 1GB DIMM DDR2 PC2-6400U DDR2-800 (5.0-5-5-18 3-23-6-3)
Video System
Adapter : ATI Radeon HD 4800 Series (Prerelease - WDDM 1.1)  (1GB, PCIe 2.00 x16, SM5.0)
Storage Devices
Hitachi HDT725032VLA360 320GB (SATA300, 3.5", 7200rpm, NCQ, 15MB Cache) : 298GB (C:)
MAXTOR STM3500630A 500GB (ATA100, 16MB Cache) : 466GB (E:)
WDC WD3200AAJS-00G0A0 320GB (SATA300, 3.5", 7200rpm, NCQ, 8MB Cache) : 298GB (D:)
ASUS DRW-22B1ST (SATA150, DVD+-RW, CD-RW, 2MB Cache) : 2GB (F:)
Logical Storage Devices
Hard Disk (C:) : 298GB (NTFS) @ Hitachi HDT725032VLA360 320GB (SATA300, 3.5", 7200rpm, NCQ, 15MB Cache)
New Volume (D:) : 298GB (NTFS) @ WDC WD3200AAJS-00G0A0 320GB (SATA300, 3.5", 7200rpm, NCQ, 8MB Cache)
Hard Disk (E:) : 466GB (NTFS) @ MAXTOR STM3500630A 500GB (ATA100, 16MB Cache)
GB1CULFRE_EN_DVD (F:) : 2GB (UDF) @ ASUS DRW-22B1ST (SATA150, DVD+-RW, CD-RW, 2MB Cache)
Peripherals
LPC Hub Controller 1 : ASUS (ICH9) LPC Interface Controller
Audio Device : ASUS HD48x0 audio
Audio Codec : AMD (ATI) AA01h
Audio Device : ASUS Virtuoso 100 (Xonar D1)
Audio Codec : Gammagraphx 0000h
Serial Port(s) : 1
Disk Controller : ASUS (ICH9) 4 port Serial ATA Storage Controller 1
Disk Controller : ASUS (ICH9) 2 port Serial ATA Storage Controller 2
Disk Controller : ASUS JMB36X PCIE-to-SATAII/IDE RAID Controller
USB Controller 1 : ASUS (ICH9) USB Universal Host Controller
USB Controller 2 : ASUS (ICH9) USB Universal Host Controller
USB Controller 3 : ASUS (ICH9) USB Universal Host Controller
USB Controller 4 : ASUS (ICH9) USB2 Enhanced Host Controller
USB Controller 5 : ASUS (ICH9) USB Universal Host Controller
USB Controller 6 : ASUS (ICH9) USB Universal Host Controller
USB Controller 7 : ASUS (ICH9) USB Universal Host Controller
USB Controller 8 : ASUS (ICH9) USB2 Enhanced Host Controller
FireWire/1394 Controller 1 : ASUS FW322/323 IEEE1394 OHCI FireWire Controller
System SMBus Controller 1 : Intel 801xx/63xx SMBus
Printers and Faxes
Printer : Microsoft XPS Document Writer (600x600, Colour)
Fax : Microsoft Shared Fax Driver (200x200)
Network Services
Network Adapter : Realtek RTL8169/8110 Family PCI Gigabit Ethernet NIC (NDIS 6.0) (Ethernet, 100Mbps)
Network Adapter : Marvell Yukon 88E8056 PCI-E Gigabit Ethernet Controller
Power Management
Mains (AC) Line Status : On-Line
Operating System(s)
Windows System : Microsoft Windows 7 Ultimate 6.01.7000
Platform Compliance : x86
Windows Experience Index
Current System : 5.7
Performance Tips
Tip 2546 : Large memory modules should be ECC/Parity.
Tip 2 : Double-click tip or press Enter while a tip is selected for more information about the tip.
in the bios im running 1.41 v on the cpu to to achieve the overclock i have now of 3.53
i have tried so many diffrent things and i cannot get close to 4 ghz..i think my ram is killin me or something..
umm that is ddr2 1066 ram btw...
sandra says its 800 but its not ...
pll:1.6
nb:1.7
sb:1.2
ram:2.25
i ran this chip up to 1.6v on the cpu and i could not hit 4ghz
tried 9,8,7 multi with no luck..
Code:
SiSoftware Sandra
System
Host Name : SIM-PC
User : sim
Processor
Speed : 3.51GHz
Type : Quad-Core
System
Chipset
Memory Module(s)
Video System
Storage Devices
Peripherals
Serial Port(s) : 1
Printers and Faxes
Network Services
Power Management
Operating System(s)
Performance Tips
pll:1.6
nb:1.7
sb:1.2
ram:2.25
Well 450 FSB with a 9 multi will get you 4.05ghz, are you able to get 450fsb at a 8/7/6 multiplier?
Yes I tried 8/9 multi simiular numbers
Tried 333 and 400 also auto did not work
I don't know the vid cpuz dosent tell
but I'm betting I got one that won't do it just because I tried so many times with so many difrent numbers etc etc
I kid you not I prob spent a few weeks trieing nrearky every number volt combo that made since to me
that chip is going to run real hot at 4ghz. Try using only one stick of ram. how dose 450x8 go? get that stable, then try for 450x9
I see what ya mean..get the multi right with everything stable x8 then try x9
I didden think of that
I'll try that and the one stick of ram when I get home
Wow1.65 I'd never do that way too high for my benching
I thought bolting it past 1.6 was like terrible for it
It ruins the metals and what not right??
Thanks at this point luck is what I need LOL
i wouldnt go from 450x8, then straight to 450x9, i can almost say with certainty that its not gonna work like that. just oc with the x9 multi, and see how she scales like that.
k so far the work up to 420x9 is working beautifuly...
ive not yet jumped to 450...
im working on it still...
ok no single channel did not reviel anything better..
also ..note to self no overclcoking when tyred..
lol
I forgot how much it took to get me that verification at 4.4, it was at least 1.7v, possibly 1.75.
I'll probably be doing some benching next week with a pot of DICE; now that I've found out why I was being held back I can try for 4.4 again. I'll let you know the results, in case it might help.
Of course, it probably won't if you don't feel like running 1.6v (More like 1.9 :D) or more. I like to volt the snot out of my chips, lets 'em know who is in charge.
Lmao too funny
Thanks also I think I'm done for now there's no way I'm gunna hit it
I'll wait till Christmas to get the latest quad for cheep
Btw it's true anything over1.55 does reduce the life span dramaticly and it does damage that sensitive metal in there
But I'm alot like you volt the crap outa it that's why we bought it LOL
today i have achieved 3.87 ghz pretty stable 1.45 on the cpu :)
I thnk the nb needs 1.8v to reach 4ghz so Im una me to hit it
New Board reccomendations??????
Why do you wanna hit 4 GHz so much? It wont be stable anyway and if it is stable you will just be degrading your chip fast. Have your Q6600 run at 3.6 GHz with a safe voltage, no point in killing your chip so fast right? I hit 4 GHz once, but it wasnt even remotely stable with 1.55V would BSOD as soon as any reasonable load was put on it.
The why bit is why we are here. The passion of pushing the hardware close to, right at, and far, far past it's limits for bragging rights or personal enjoyment; that's exactly why.
Even if it does crash right after you save the validation. :)
Yes, but is that worth a new motherboard? :p I agree pushing hardware as far as you can is fun, but you also need to weigh it up against the cons. Paying 150 euro for just a validation at 4 GHz is a little over the top for me.
