Hi there this is my first post so I figure I'll make it a good one.
I'm in the process of overclocking my q6600 aiming for 3.6 on air.
Specs;
Q6600, 3600 MHz (9 x 400) G0 Stepping B thermalright ultra 120 heatsink
Gigabyte GA-EP45-DS3
2x G Skill F2-8000CL5-2GBPQ
@ 400 MHz 5-5-5-15 (CL-RCD-RP-RAS) / 24-51-3-6-3-3 (RC-RFC-RRD-WR-WTR-RTP)
@ 266 MHz 4-4-4-10 (CL-RCD-RP-RAS) / 16-34-2-4-2-2 (RC-RFC-RRD-WR-WTR-RTP)
AMD Radeon HD 6870
Max Power 500w PSU
Microsoft Windows 7 Professional 64bit
First thing i did was make sure my bios version was the latest and remove my 2x 2gb Adata ram sticks (originally had 8gb) because it was effecting me booting into Windows at 3.6. Now with the 2 G Skill this doesn't seem to be a problem.
Guides I've read;
http://www.overclock.net/t/289573/my-experience-overclocking-the-q6600-a-basic-guide-walkthrough
http://www.bit-tech.net/hardware/cpus/2007/07/25/overclocking_intel_core_2_quad_q6600/1
and many others.
Basically I can boot into windows at 3.6 at 1:1 with idle temps off 41C or there abouts (readings from Core Temp).
CPUs VID is 1.3v and CPU-Z tells me I'm at 1.392v at idle.
Every time i run Prime95 I get failure on on core 1 straight away.
I've done my reading about vcores, ratios etc but I'm still very much a newbie when it comes to overclocking and some advice regarding getting some stability at 3.6 would be very much appreciated.
I'm going to reboot and then post my bios settings. I shall return!
Specs;
AMD Radeon HD 6870
Max Power 500w PSU
Guides I've read;
and many others.
