I've just started to overclock my computer for the first time.
I have a Q6600 w/ G0 stepping
Corsair 4x1GB PC6400 800MHz set at 4-4-4-12 with 2.1v
EVGA 750i FTW mobo
xFx 8800GTS XXX 640MB
Antec 500W
The problem I keep running into with trying to overclock is high temperatures.
Right now I set the machine back to stock with the exception of the memory timings and voltage and at 2.4Ghz, Prime95 is making the cores run from the low to mid 50's.
I have the ThermalTake Big Water 760i to cool the CPU so at this point, I'm not sure why my temps are running this high.
At idle the cores range from about 42-46C but never even dip into the 30's. Is this normal for a liquid cooled setup? Shouldn't the CPU being running even cooler than that on liquid cooling?
I just took the machine apart again earlier and made sure everything was tightened down properly, liquid is running fine, little to no air bubbles in the tubes, etc.
I can get my machine running stable at 2.8Ghz but the temps rise to the low to mid 60's under full load. And lets not even get into how high the temps started to go trying to do 3.0 or 3.2Ghz.
Anyone have any advice?
Thanks
EVGA 750i FTW mobo
Antec 500W
Thanks
