- Aug 11, 2007
Hello Everyone,
I have a new computer I built, specs are as follows:
Q6600 B3
BFG n650i Ultra
2 GB Crucial Ballistix DDR2800
320 GB SATA 3.0gb/s
8800 GTX
I am having trouble dealing with the temperature of this processor. First of all, let me ask, which tool is more accurate, SpeedFan or CoreTemp? I read about the Tijunction issue where most temp readers report 15C less for quads, is this still the case? The reason is, what my BIOS/nvidia control panel/speed fan reports is significantly different than what CoreTemp is reporting.
At this point, I will be listing the temperatures and continue my post using the numbers I got from CoreTemp, so please keep that in mind.
The CPU was running around 40-50C idle and 55-60C under load with stock heatsink and fan. Then I bought the Zalman 9700 thinking it would help bring down the temperature around 25-30 degrees, oh boy was I wrong.
After $60 + $5 tax + $6 shipping for the fan, all I got was 35-40C idle and 48-52C under load. Is this normal?
Now, to the second question I had, for overclocking, I tried 3.0 Ghz so far with 1333 Mhz FSB. The temperatures are 50C idle and around 65-68C under load. Is this normal and more importantly within limits? Would I damage the CPU if I kept using it this way? I have never done overclocking before so I would appreciate it if you can answer the following questions:
1. The way I did it was to go into BIOS, change the FSB (I did not touch the voltage), unlink the FSB and RAM speed (or RAM would go all the way to 900 Mhz). Is this correct way?
2. When I overclock the FSB, I saw that voltage went to 1.45 from 1.25, is this normal?
3. When I overclock the FSB, I am also seeing PCI-E bus uses 1.40 instead of 1.20 which even resulted me losing ALL my usb devices at some point and I had to flash the bios. I'd start windows and the message "USB Device not recognized" would show for maybe 15 times. Is there anyway to make it so that it doesnt affect PCI-E bus?
4. This isn't about CPU, but when I try and overclock the GTX to 659/1006, it worked, but everytime I restart my computer, the settings won't stay. The only way I can do it is through control panel not bios and it's not effective in next O/S start up. Is there anyway to fix this and save?
Now on an unrelated subject, which I will be posting in to memory forum, I am having memory issues as well. The memory I have is 4-4-4-12 at 2.2v. My bios can only accept 2.1 max and it reads my RAM as 5-5-5-18. Should I switch to 4-4-4-12 manually? Should I return the RAM and get one that runs in lower voltages? I am really illiterate on this topic, I would really appreciate it if you shine some light on the topic.
Also, when I ran memtest, I found some errors. The thing is, it ran for 12 hours fine and then back to back 11 errors after. I did it again, for 15 hours, there were no errors, but then same thing. Is this normal? The problem is, almost all my games CRASH at some point. Battlefield 2, Supreme Commander, FIFA 07, all crash. The game just freezes and sometimes there is repeating sound, or sometimes it just restarts. Do you think this is about the RAM or something else?
I apologize for the length of my post, but I really need you guys' help. Thank you very much for your time, I am glad I joined this forum.
Regards,
ThePredator
Q6600 B3
BFG n650i Ultra
320 GB SATA 3.0gb/s
8800 GTX
Regards,
ThePredator
