Well I just built a new PC, which consisted of the Phenom II X4 965 BE. I first noticed the stock voltage is 1.475 , which is really high. Stock voltage is about 1.40 so I went into the BIOS and manually changed it to 1.40, but also changed the CPU multiplier to 19 to achieve 3.80Ghz and saved the settings + rebooted. I went into Windows, and I noticed the voltage didn't change. I assume some of that AMD default control stuff is conflicting with my settings. And I know there is 2-3 different things that Should be disabled upon overclocking to achieve best results. I often have my computer on for long periods of time and I'm not going for a insane overclock, so my question is - Is it possible to leave the settings which allows the motherboard to undervolt and underclock my hardware, without it causing this weird problem? Maybe there is something I can try? I updated the BIOS to the latest BIOS too. I have AOD ( I know BIOS is best, but supposedly AOD is nice for making testing quicker for finding the MAX for a setting ), could AOD be conflicting with it? I have no idea even how to work the thing, I changed the slider to make my CPU 3.8Ghz and it didn't show a change in Windows upon applying the change lol.
Edit: or if it must be disabled, is there some alternative software that can give the same effects in the same way, but without problems?
And this is my MOBO, though I doubt its needed -
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128521
