- Oct 12, 2001
- Los Angeles
The bottom line is that ANY time the water has to change direction, even by all small amount, it all adds up to resistance. WB's typically have 2 90 degree fittings, but nothing you can do about that. What we try to strive for is obtaining the least amount of restrictions as we can. I have a massive u-turn in my tubing, and that adds to the resistance as well except there is nothing I can do about it with the way i have it set up. Even "t" fittings for a bleed line are hogs, worse than a 45 degree sweep. Again, it is about minimizing the flow pigs. Here is a pic of my biggest flow killer:thorilan said:anyways my question nik is did you test various curves that wher not joints too ? i would imagine the coeficient would be much less for them but again i could be wrong
I want a semi tight 90degree turn using copper tubing (possibly less of an angle i hope) and i hope that metal tubing will be the answer
