Hey guys, so I received a broken Power Mac G5 2.5 Quad which comes with a pretty hefty aluminum radiator, 2 Delphi (I believe D5) pumps and its own water block and tubing for its dual processor configuration.
My rig is as follows
Case: Cooler Master HAF 912
PSU: EVGA Supernova 1000 G2
MoBo: Gigabyte P67X-UD3-B3
CPU: Intel Core i5-2500k
Ram: Patriot G2-8GB-1333Mhz
GPU: Sapphire Radeon HD 7990 (reference design)
CPU Cooler: Corsair A70
My question is when I finally get that damned cooler out of the Power Mac, Could I reuse the Rads and Pumps and watercool my Radeon 7990?
Here is an image of what I want to do:
What I also planned on doing was spray painting the sides of the Rad Black (not the fins, just the side walls) and maybe making a shroud on top with some sheet metal aluminum to keep it clean looking.
Another thing would be fan, which I would most likely get a 200MM fan and run that at the top of the case. The main reason is that going through some Power Mac forums, the radiator is so large that even without fans it can cool really well, I would obviously want to run a fan for redundancy but still.
