Good morning good folks of the OCers forum.
I am trying to clear up some confusion I'm having about LED interfaces and controllers that I ran into while building a computer with a Gigabyte x570 motherboard. I have done some initial searching on the web so that I don't have to ask about something I can easily look up.
The issue I'm confused about is that there seem to be two different digital aRGB interfaces. Both use 3 pins, but one has a connector that is 4 pins wide with a single missing pin. The other one appears to resemble the 3-pin fan interface, with two "fins" that fit into slots on the interface to ensure the correct orientation. This 3 pin led interface is for the led control for both my GPU and CPU waterblocks, from alphacool and swiftech respectively.
Now the motherboard has two different LED interfaces, the "4 pin wide with 1 missing pin" which the guide refers to as a 5v digital led interface, and the 4 pin analog 12v. I know the 3 pin standard "fan looking" connector can't go to the analog 4 pin header, but is there a way to adapt it to the "4 pin with 1 missing pin" header? is there a specific name for these interfaces so that I can easily search for them and their adapters?
