- Jul 28, 2015
For those of you using Mayhems Pastel coolant, how often to change the liquid/clean the loop? Can you go a little longer than just water before the liquid becomes conductive?
You getting better results with Mayhem rather than distilled water?
Well that's disappointing lol. When you clean the loop, do you re-use the Mayhem coolant or do you buy new liquid?
How often are you cleaning and refilling your loop with distilled water?
