- Sep 2, 2002
- Haiku, Maui
I bought a second hand UPS on ebay a while back, the seller saying there was a new battery installed... I've been noticing through testing (and blackouts) that it will last me only about one minute before shutting down.
It's an Eaton Ellipse eco 800 which uses by default one 12v 9AH battery. So I opened the case today to see what was happening... Basically I have a couple of 12v 7AH batteries sitting around and was thinking the guy had probably lied about there being a new battery in the UPS. I was thinking to replace the "bad" battery with a good one, but of lesser AH.
To my surprise, the battery inside *was* a 12v 7AH battery. It gave a 13v readout on my multimeter. Seemed good.
Anyway, I was wondering if this is the reason that the battery will only last one minute and if I throw a 9AH battery in there to fix it, the problem will end. Or what?
Any help with this conundrum appreciated. Thanks
