- Nov 1, 2001
- New Iberia, LA
The case actually isn't that small, bing. That's an Antec 1040 clone, which used to be one of the larger cases back in it's heyday.
The shared pwm's work just fine. And I have the rpm sensors separated; one with the pwm wires and the other on a separate 3 pin fan plug. The motherboard monitoring in bios actually showed the fans turning a little slower than the rated speeds on the Sanyo Denki site.
Bing, can you tell me the minimum PWM rpm, wich this Sanyo Denki 9GL1212V0J03 is capable?
