System is below, and I run it clocked between 4.5-4.8. I am considering adding a 6970 to this loop because I am able to obtain it cheap, as in $70 from a friend. I will have to pay for cost of a block to add it to loop. I would like to keep this system another 7mth to year before upgrading. Temps under load sit at around 60-63 running 4.6-4.7
From systems performance I am sure the current system should be able to handle the 6970, I will not be overclocking the gpus too much, only when needed.
Sabertooth Z77
2700K
6990
16 GB DDR3 @ 1866
XFX 850 w psu
Switch 810 case w 4x140 Case fans
Blue ray
240 SSD
2 x 640 WD Blacks
1.5 WD green
Swiftech Dual 120 rad w MCP35X pump w 2x GT AP15 120mm fans
Swiftech QP Dual 120 Rad w 2 x Cougar 120mm fans
Thoughts? I know for tri fire I will need to upgrade psu but that can be carried over to next build as well
Sabertooth Z77
2700K
6990
16 GB DDR3 @ 1866
XFX 850 w psu
Blue ray
240 SSD
2 x 640 WD Blacks
1.5 WD green
