- Dec 29, 2010
Scroll down to summarize" section, if you want to go to the question.
Hello, i just recently registrated this forum but i was a reader for a good time
I'm actually in a project of trying to obtain the maximum performance out of a Dual Pentium III-S 1.4Ghz Tualatin (currently overclocked to 1.6Ghz at 155Mhz bus speed, but waiting for overclocking it further more because of an old soundcard which can't work with more speed bus)
Now, i'm planning to buy a Corsair 60GB SSD, but i have actually 2 HDD Sata (500GB-sata2 and 250GB-sata1) connected into a SATA to PCI controller.
I know the bottlenecks of PCI to SATA technology (and obviously of SSD) though i think i will get a boost performance installing an SSD (and whatever i want to try it).
As i'm using a Pentium III, PCI-e and onboard sata connections are not an otpions, so i will have to install the SSD via PCI or IDE controller/adapter.
I have some questions..., the PCI speed badnwith is shared by all the cards connected to it, so perhaps i should try to avoid this using my IDE interface.. but again i don't know.
In summarize:
Which scenario you think would do the best performance for my SSD?
1- SSD alone on PCI (and i will buy then a 1TB SATA to connect via IDE)
2- SSD + 1 HDD on PCI and the other HDD on IDE
3- SSD + 1 new 1TB HDD (which i will buy)
4- My currently set up of two hdd's on PCI and SSD on IDE
I would want to evade to buy an extra HDD SATA, and keep my currently ones, but if i have to do it (because is the best option), i wwill do it.
I appreciate any comments on it, thank you!
In summarize:
