- May 22, 2005
I'm putting a VGA Silencer on my 9800PRO 128MB. Will that cooler be sufficient for me to be able to use higher than 9800XT stock speeds while still cool?
I also found some vga memory heatsinks that i can use, they cost $10 (aluminum), or there are copper ones for $4 more ($14) and what would I use to put them on if i didn't use the tape?
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=1283740&CatId=496
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=1283741&CatId=496
would these work?, or are they unnecessary?
And does anyone have a guide to installing the VGA Silencer on a 9800PRO 128MB?
