- Aug 27, 2003
- Mississauga, Ontario
My new rig is in the sig. Yes, I looked for solutions online and did what they suggested but no luck and I need some more info anyway. My new system is VERY low volume, even at 100% volume, and 100% in Media Player Classic it's just enough to enjoy a movie, and I have it plugged into an amp.
On my old AM3 system I also had Realtek and it was really good, very loud, with RT HD Audio Manager. It was so loud and clear I never had to put the overall system volume above 50% and even with that, inside media players only 20% for comfort and up to 50% for very loud. 100/100% was still clear but it sounded like listening to a CD on my system, in other words, perfect.
I have a audio system that is plugged into the computer at the back,like before. But with the new build, everything is quiet. I have my system at 24 of 30 now (before I always kept it at 18 volume and it was loud already).
Under device manager I see AMD High Definition Audio Device and Realtek High Definition Audio, both of which are updated to the latest drivers (2019/07).
I uninstalled both completely and deleted the drivers, then re-installed the Asus Realtek latest driver, and both of those device manager entries came back, but everything is the same.
I do not see the HD Audio Manager anywhere, not in control panel, not when I click on volume control, it looks like just your regular windows 10 driver.
I don't know if that would fix it, but I can't find where to download the Realtek driver itself, not on Asus or AMD, but Realtek, with HD Audio Manager with it.
Also, on my old system I only had Realtek, but was able to use Dolby Plus, this audio manager that I could control volume but also voice and EQ and all kinds of things, that thing was awesome, but I can't find that anywhere either (and no, I never did have dolby, it was not needed).
Any help would be appreciated!
