- Jan 13, 2014
SO I'm experiencing an issue similar to this one:
http://forums.amd.com/game/messageview.cfm?catid=475&threadid=170551&enterthread=y
Basically when I have Crossfire enable in either 290's or 290'x I will get sound stutter (If using speakers).
NOW If I use my Headset (wireless Sony PS3 Headset) My usbs will go bananas on me and power cycle and eventually get locked, at the point I have to restart the PC.
1) IF I alt tab and the game goes to window mode it works perfectly (if using onboard audio), I heard this is cause Crossfire only works in Full screen mode, is this correct?
2) People are claiming that if I use a third party uninstaller to uninstall the current driver and install amd_catalyst_13.11_beta9.2 It should work again (if I don't use the third party software It wont work) Question is: What is the name of this program?
3) I have unlocked and flashed my XFX 290 into a 290x (shaders where unlocked), My powercolor only was only flash. I can see the performance difference while mining (since I dont crossfire)
But when I game Will it still behave as 2x290's (using least common denominator) or will it behave as a 290x/290 mix since they are flasshed?
Also could this be thereason Im crashing? Since my powercolor 290 is flashed to 290x for stability?
Update:
Its called Driver fusion.
Update:
