Yea... I'm searching my stash for some now. My fault for not reading on it more.Don't use the adhesive, it is permanent...try to use something else like thermal pads.
The Accelero comes with an adhesive to put the small heat sinks on. That is what ivan is talking about.
Yes, I know, that's what I am talking about as well.
It's really easy to remove and clean up.
How did you remove it then? heatgun?
Oh, too bad...why no classified???
I would imagine most flash to the higher power limit bios' so that is why you are seeing those results. I haven't seen (but is likely out there) a bios for the HOF yet.stock bios for stock bios
