- Aug 7, 2012
Hey, i'm looking to overclock this GPU i just bought
How should I proceed?
My computer specs on the signature
Hm, that sounds scary lol.
I think i'll just stay at my stock voltage then,
I'm also wondering how do you test your GPU for stable?
I hit 850/1200 on my OC quite easily without problems and I ran Unique Heaven on Extreme benchmark for a full cycle, is that enough to test for stable?
Don't use Furmark, its not good for your GPU
To unlock MSI AB go to Settings >> General Tab >> check Unlock Voltage Control >> OK >> OK / Yes.
Don't set such high volts
Okay so my GPU is running at 850/1165 on stock voltage and ran unique heaven with no errors on september 17th.
Just yesterday, whenever I try to load a video on youtube or some video, my audio + mouse stutters for split seconds constantly.
Now my desktop does this as you can see in the image, there's a repeat of graphic error whenever i drag a folder or whatever across my desktop screen very fast.
What do you guys think the problem is? I already tried a fresh reformat but the problem remains
Update:
I went to run Memtest86+ to see if my ram was faulty
I got an error similar to this within 2-4 hours of testing
I looked around google to see why my memtest86+ was giving this error and it seems like the cause is the video card.
Did I do something to ruin my video card? I never changed the stock voltage and the GPU has been reset to 775/1000 ever since i had this error yesterday but nothing is fixed
