- Jun 6, 2002
You want a $50 video card with a 256-bit memory bus? You sit there and talk about "They can just reuse the 3850 PCB", when it's quite likely the 3850 PCB cost them more than you want to pay for the entire card and the packaging and cooling that must go with it?
I'm ignoring the rest of your post, because if you can't grasp the above, then you won't understand the rest. A PCB is not a $5 part; "already have one" is not a cost-savings function. And if you want a $50 video card that can play back BluRay, then you'd best be prepared to spend $200 on a processor.
ALB
you really need to go back and reread my posts. no where did i ever state a 256bit card for $50. you just put that in your own head.
Here
it wouldnt be that hard for them to fill out the rest of the line. look at the pricing gaps. its $49-65 and $79-99, so we have a hole in $66-78 you could fit the 128bit 3400 in there. how about the fact they have a hole from $100-$174. being as the 3850 256mb card is 174 msrp, cheapest on newegg. why not put a 3600 in the $100-175 range? ati wants/needs the money, how hard is it really to just yes they have a hole and could possible do this? the could just as easily use the 3600 to make a 3400 with 128bit. as well use a 3850 to make a 3600 with 256bit...ati has left open some areas,imo.. like a 128bit 3400 or a 256bit 3600... dosent have to be high end.. just give the lower end at least one card to be worthy of buying in that section.
now where did i say 256bit card for $50? i will once agian say if you have some problem then just drop it. as it seems you cant though for what ever reason.
*edit*
just adding..
that i dont see the 64bit cards worth the money, make just one 128bit now you have my interest. i need to go check but i thought the 3000's added blueray/hd-dvd hardware support, if not then i guess im waiting..
