LethaLHooK
- Jan 16, 2019
Good evening, I would like your opinion on 3 radiador. I want a radiador up to 30mm thick because I have a relatively small case with big card (Fractal Design Define C and Gainward 1080 GLH).
* 1) EK-CoolStream SE 360 (Slim Triple)
* 2) Black Ice Nemesis Radiator GTS 360
* 3) Alphacool NexXxo ST30 Full Copper 360mm
Alphacool and Black Ice GTS have 16 FPIs in contrast to the 22-year-old EP. I would buy Alphacool but I would like to take a second view. On the one hand, I think because it is thin as radiador (30 mm) if it had more FPI it would be a bit better. I am also interested in the issue of noise and I also go to water cooling. I'm among 3 fans:
* 1) Be Quiet Silentwings 3 PWM 120mm
* 2) Noiseblocker M12-SP
* 3) Noctua NF-F12 PWM Chromax Black 120mm
There will also be another radiador 240mm (It will be both cpu and gpu in the loop). I deal with 3D renderings both in image (vray rhino kai 3ds) and in video (lumion), but I also play games demanding several times like crysis, the witcher, etc.
If you can tell me what you are suggesting as far as radiador and fans are concerned.
