About to start a new build with a Phanteks Enthoo luxe case. Quite a bit larger than my current Fractal Design S case so I assume there will be no issue installing my predator 360 radiator at the top.
However, in checking my rad dimensions I see it is on the thick side at 68mm, and most builds I've read suggest a maximum 60mm thick rad on top.
Checking the actual Phanteks specs I see 69.85mm clearance to mobo.
https://benchmarkreviews.com/19262/phanteks-enthoo-luxe-full-tower-case-review/6/
So my question
Is less than a couple mm enough clearance?
If there is any heat from the rad then I assume that means no and I will need to invest in a thinner rad.
Any wc experts care to chime in?
Thanks!
So my question
Thanks!
