- Sep 15, 2015
- Pensacola, Fl
If surface area is the name of the game, can thickness compensate for length? First lets take fans "out" of the equation, I have noctua ippc 3000's so I feel I'm relatively optimized for any thickness/fpi. Second lets compare the alphacool nexxos 280mm UT60 to the 560mm ST30, let's also pretend they have the same fpi(performance-pcs lists the UT60@10fpi, and the ST30@16fpi). Now let's throw the fans back in the equation, crank up to 100%, and see what happens. I know at a certain point more rpm's will not be beneficial on the ST30(I have no idea how the physics on this works), but let's just assume that's not a factor. We have 2 radiators with roughly the same surface area, that will dissipate roughly the same amount of heat, correct?
