Background:
I got my feet wet, both literally and metaphorically speaking, on watercooling on two different Koolance cases over the last decade or so that I've been less than completely pleased with, but I've never hand-built a watercooling system before. My priorities are stability and quiet before speed, but I don't want to lose speed if I don't have to. I'm guessing I'll probably OC the 920 to around 3.2Ghz and stop there as "good enough". I do own a Dremel and am not afraid to punch a few extra holes in necessary spots, though I'd like to avoid something so extreme as removing sections of case wall, particularly since one of the features of this case is sound insulation.
The new system I'm building is for a gaming/programming desktop replacement for a system that I've pushed far past its normal life cycle. The case, an Antec P193, has already been selected and ordered. I intend to put in it a MSI Eclipse X58 with an I7-920 chip and a single Powercolor Radeon 4870x2, both watercooled, and most likely a 10gig ethernet card and a sound card later, along with three hard drives. I'm aiming at keeping the water temperatures to 50C or below.
Proposed Components and Questions:
A couple days of research has led me to the following components as likely best suited for my purposes:
CPU block: Swiftech Apogee-GTZ w/GTZ-Ci7 Hold-down
Video block: Danger Den DD-4870-X2
Hard Drive block (for main drive only): Alphacool HDD3 (using this forces 3/8" tubing or a converter)
I had selected the Swiftech MCRES-MICRO-REV2 reservoir to be placed on a swing-out L-bracket mounted to the side of the 5.25" drive bays as being a good combination of quiet and easy access for filling, draining, and removing air from the system, but was also contemplating sacrificing one 5.25" bay for a XSPC Plexi Bay reservoir. I'm already sacrificing 1U for the controller/monitor, however, so I'm leaning towards the Swiftech.
For a pump, I'm intending to use the Swiftech MCP350 for reasons of both size (it looks like it'll fit inside a single 5.25" bay, and I'm going to have some blank space inside one behind a temperature display/control unit), but I have some question about whether or not it's going to be sufficient for everything in the loop. The case is large, especially since I'm not sticking most of my storage in it for this build, so I could in theory allocate some of the extra space for a second loop, but would prefer to keep things simple if I can, so question 1 is:
Q1: Should I use a Swiftech MCP655-B or some other pump instead?
I'd had my eyes on those two as being explicitly advertised as very quiet, but will cheerfully consider something else instead. I do note, however, that going to the 655B forces me into 1/2" tubing, which may conflict with my plans to cool my one high-speed drive, and it seems to have lower pressure, if that's significant. I can probably live with just air-cooling for the drive if necessary; the case should have fairly good airflow.
The case itself comes with two 120mm fans pushing air out the top, and one 120mm fan pushing air out the back, as well as two tube ports built into the back and a single 240mm side intake fan. A picture can be found here. This leads up to the part I'm guessing randomly at: what kind of radiator setup I need, and I'm guessing I'm going to need a lot of surface area because I want to keep the fans quiet.
Plan 1: I stick a XSPC RX240 on top of the case, and a XSPC RX120 behind it. This has the advantage of being very simple, with the fans inside the case pushing air out through them. Unfortunately, I'm having a hard time guessing if it's going to be enough, especially if I decide in the future that I want to get really silly with my video card and go for a second board in a quad-crossfire rig. I probably won't do this, but wouldn't mind not having to repurchase a completely different radiator system if I did.
Plan 2: I stick a XSPC RX360 on top of the case, hanging out towards the back, add an extra fan blowing downwards, keep the XSPC RX120 behind the case. This gets a bit more surface area, at the cost of some awkwardness (which I can live with) and possibly a small amount of extra noise, but since the case seems to end right after the fan mounts, it might be workable. It can be made easily workable if I move all of the fans outside the case, but then I lose some of the noise shielding.
Plan 3: Again, I keep the XSPC RX120 behind the case, but I stick a pair of linked Swiftech MCR220-QP-STACK radiators on top. This gets me the equivalent of 5x120mm radiator segments, but notably raises the height of the case and moves two fans outside the sound shielding of the case.
Plan Mod B: As with each of the above plans, but replacing the rear port fan on the inside of the case with a 38mm deep fan, sticking it on the outside of the rear port, and replacing the RX120 with a RX240 there hanging down, and hoping that the nearly 4cm of spacing room is sufficient to get all the cables and tubes out of the way behind it. This scares me a bit, but gets me extra surface area.
Plan 4: I pull out the top two fans and completely seal the top opening with soundproofing material, keep a RX120 at the rear, but then run the tubing out a little further and stick either a RX480 or a dual MCR320-stackable with attached fans around the corner of my desk, just standing up against something. That generates a lot of surface area, and maybe hides some of the sound of the external fans, particularly if I liberally apply thick soundproofing material to the desk itself.
So, the next questions are:
Q2: How much surface area do I actually need, cooling at a minimum a 3.2Ghz I-920 and a 4870x2, with a maximum coolant temp of 50C?
Q3: Which of the above plans seems like the best general way to get there, if any?
And then finally, on the topic of monitors and fan controls, perhaps someone could recommend between these two:
Lian-Li TR-5B and Koolance CTR-CD10. The Koolance is more expensive and bulkier, and I know it's not exactly a favored name, but it does seem to have a substantially better interface and the ability to set fan speeds automatically.
Thanks for any advice you may have.
