Lvcoyote Overclocked Moderator, Overclockers.com Lead Edito Joined Apr 10, 2002 Location Omak, WA Dec 5, 2012 #21 Actually starting on page 3-32 there is a walk through on a few different ways of flashing the BIOS.
jazon1 Member Joined Jan 19, 2010 Location USA Dec 5, 2012 #22 before trying to re flash or anything else extreme try the MemOK button usually will fix a good 90% of memory problems on ASUS boards.
OP C ComputerNewbie8 Registered Joined Dec 5, 2012 Dec 5, 2012 Thread Starter #23 two of these >> http://www.newegg.com/Product/Product.aspx?Item=N82E16820231313 and two of these >> http://www.newegg.com/Product/Product.aspx?Item=N82E16820231488
OP C ComputerNewbie8 Registered Joined Dec 5, 2012 Dec 5, 2012 Thread Starter #24 I tried the MemOK button too, still doesn't work..
Lvcoyote Overclocked Moderator, Overclockers.com Lead Edito Joined Apr 10, 2002 Location Omak, WA Dec 5, 2012 #25 It'll be tough to run all those together, they have different timings. Did you buy two single sticks?? If you did, you should have bought them as a kit (2X8Gb), which ensures they will run together.
Lvcoyote Overclocked Moderator, Overclockers.com Lead Edito Joined Apr 10, 2002 Location Omak, WA Dec 5, 2012 #26 ComputerNewbie8 said: I tried the MemOK button too, still doesn't work.. Click to expand... Ok, put your old memory back in and flash the BIOS using your manual for instructions. I recommend using the EZ flash method described in there.
OP C ComputerNewbie8 Registered Joined Dec 5, 2012 Dec 5, 2012 Thread Starter #27 I bought them as a kit. I didn't buy them individually.
larrymoencurly Member Joined Jul 14, 2002 Dec 6, 2012 #28 Just wondering, but what if you reverse the positions of those two 8GB DIMMs? Is it possible the new memory is from a company whose strict standards allow 2 bad bits per DIMM?
