Hello First time posting long time viewer. Got a technical question hopefully someone will be able to assist me with.
I have a Asus P5k-E Mobo running a 4GB Dual channel kit for the past 3 years. Recently while running Vista 64bit (don't judge me!) I experienced BSOD. I'm not a complete computer wiz but I do understand the basics. I did a memtest and windows memory diagnostic and found out I had faulty ram.
I have a warranty with the manufacturer and a RMA is in the works but I need to send both sticks to complete the warranty. In light of this I need to purchase new ram in the meantime but I want this new ram to compatible with the old when I get it back. I understand mixing Ram is a bad idea and I should try to stick with same size brand/timings but this is high performance ram that is out of production and no where to find. What options do I have?
The old faulty Kit is a Patriot Viper Series DDR2-6400 800MHZ 4GB kit (2x2GB). Built for Timings of 4-4-4-12 @2.2V.
Another thing is that I've never intentionally over-clocked it and I set the Bios to AUTO settings so its been running at 1.8V @ 5-5-5-12 All this time.
Would anyone be able to suggest a similar 4GB kit to match this current one? Also what would happen if I mixed another dual channel kit that clocks at 5-5-5-18 @1.8v, would my bios on auto match the slower ram?
Any insight is greatly appricaited. Thanks in advance.
