Report from Sandra.
Think I finally found the problem. Tell me what you think. I just visited OCZ and took a look at my RAM specs.
My RAM is unbuffered. Sandra gives this warning message in its report. Do you think that has anything to do with my problem?
Warning 100 : Large memory sizes should be made of Registered/Buffered memory.
Tip 2546 : Large memory modules should be ECC/Parity.
OCZ EL DDR PC-3200 / 400MHz / Platinum / Revision 2 / Dual Channel
400MHz DDR
CL 2-2-2-5
Available in 512MB and a 1GB (2x512MB) Dual Channel Optimized Kit
Unbuffered
Mirrored Platinum Copper Heatspreader
Lifetime Warranty
2.75 Volts
184 Pin DIMM
Special Features
Enhanced Latency Technology
2.9V EVP
Part Number
1GB (2x512) D/C Kit PN - OCZ4001024ELDCPER2-K
SiSoftware Sandra
System
Manufacturer : System manufacturer
Model : System Product Name
Version : System Version
Serial Number : System Serial Number
System Chassis
Manufacturer : Chassis Manufacture
Type : Desktop
Can be locked : No
Version : Chassis Version
Serial Number : EVAL
Asset Tag : 123456789000
Boot-up State : Safe
Power State : Safe
Thermal State : Safe
Security State : External Interface Locked-out
Mainboard
Manufacturer : ASUSTeK Computer INC.
MP Support : 1 Processor(s)
MPS Version : 1.40
Model : A8N-E
Version : 2.XX
Serial Number : 123456789000
System BIOS : 04/07/2006-NF-CK804-A8N-E-00
System Memory Controller
Error Correction Capability : None
Number of Memory Slots : 4
Maximum Installable Memory : 4GB
Bank0/1 - A0 : None None None None DIMM 512MB/64 @ 400Mt/s
Bank2/3 - A1 : None None None None DIMM 512MB/64 @ 400Mt/s
Bank4/5 - A2 : Empty
Bank6/7 - A3 : Empty
Chipset 1
Model : Advanced Micro Devices (AMD) Athlon 64 / Opteron HyperTransport Technology Configuration
Bus(es) : PCI PCIe USB i2c/SMBus
Version : 1.02
Front Side Bus Speed : 2x 1005MHz (2010MHz data rate)
Maximum FSB Speed / Max Memory Speed : 2x 1000MHz / 2x 200MHz
In/Out Width : 16-bit / 16-bit
IO Queue Depth : 8 request(s)
Chipset 1 Hub Interface
Type : HyperTransport
Version : 1.02
Logical/Chipset 1 Memory Banks
Bank 4 : 256MB DDR-SDRAM 2.0-2-3-5 (tCL-tRCD-tRP-tRAS) CR2
Bank 5 : 256MB DDR-SDRAM 2.0-2-3-5 (tCL-tRCD-tRP-tRAS) CR2
Bank 6 : 256MB DDR-SDRAM 2.0-2-3-5 (tCL-tRCD-tRP-tRAS) CR2
Bank 7 : 256MB DDR-SDRAM 2.0-2-3-5 (tCL-tRCD-tRP-tRAS) CR2
Channels : 1
Bank Interleave : 4-way
Speed : 2x 201MHz (402MHz data rate)
Multiplier : 1/10x
Width : 64-bit
Memory Controller in Processor : Yes
Cores per Memory Controller : 1 Unit(s)
Refresh Rate : 7.80µs
Power Save Mode : No
Fixed Hole Present : No
Memory Module 1
Model : OCZ4001024ELDCPER2
Type : 512MB DDR-SDRAM
Technology : 16x(32Mx8)
Speed : PC3200U
Standard Timings : 2.0-2-3-5 (tCL-tRCD-tRP-tRAS)
Version : 0.1
Date of Manufacture : Saturday, December 25, 1999
Set Timing @ 200MHz : 2.0-2-3-5 (tCL-tRCD-tRP-tRAS)
Memory Module 2
Speed : PC3200U
Version : 0.1
Environment Monitor 1
Model : ITE IT8712F LPC
Version : 7.00
Mainboard Specific Support : No
Temperature Sensor(s)
Board Temperature : 33.0°C / 91.4°F
CPU Temperature : 36.0°C / 96.8°F
Power / Aux Temperature : 25.0°C / 77.0°F
Cooling Device(s)
Auto Fan Speed Control : No
Chassis Fan Speed : 3245rpm
Power / Aux Fan Speed : 11250rpm
Voltage Sensor(s)
CPU Voltage : 1.41V
+3.3V Voltage : 3.28V
+5V Voltage : 4.97V
+12V Voltage : 11.73V
-12V Voltage : -1.50V
Standby Voltage : 4.95V
Battery Voltage : 3.14V
PCI Bus(es) on Hub 1
Version : 2.30
Number of Bridges : 5
PCI Bus 0 : PCI (1/1x PCIClk)
PCI Bus 1 : PCIe (3/1x PCIClk)
PCI Bus 2 : PCIe (3/1x PCIClk)
PCI Bus 3 : PCIe (3/1x PCIClk)
PCI Bus 4 : PCIe (3/1x PCIClk)
PCI Bus 5 : PCI (1/1x PCIClk)
Number of PCIe Lanes : 20
LPC Hub Controller 1
Model : ASUSTeK Computer Inc nForce4 PCI to ISA Bridge
LPC Hub Controller 2
Model : ASUSTeK Computer Inc nForce4 SMBus
USB Controller 1
Model : ASUSTeK Computer Inc nForce4 USB Controller
Version : 1.00
Interface : OHCI
Channels : 10
Supported Speed(s) : Low (1.5Mbps) Full (12Mbps)
Legacy Emulation Enabled : No
USB Controller 2
Model : ASUSTeK Computer Inc nForce4 USB 2.0 Controller
Version : 2.00
Specification : 1.00
Interface : EHCI
Channels : 10
Companion Controllers : 1
Supported Speed(s) : Low (1.5Mbps) Full (12Mbps) High (480Mbps)
Addressing Support : 32-bit
System SMBus Controller 1
Model : nVidia MCP2+ SMBus 1
Version : 0A.02
Advanced TCO Mode Enabled : No
Slave Device Enabled : No
PEC Support : No
System SMBus Controller 2
Model : nVidia MCP2+ SMBus 2
Version : 0A.02
PEC Support : No
Expansion Slot(s)
PCI1 (1h) : PCI 32-bit +5V PME Half-Length Used (ASUSTeK Computer Inc nForce4 PCI to ISA Bridge)
PCI2 (2h) : PCI 32-bit +5V PME Half-Length Available (ASUSTeK Computer Inc nForce4 USB Controller)
PCI3 (3h) : PCI 32-bit +5V PME Half-Length Available
PCIEX16_1 (4h) : PCIe x64 +5V PME Half-Length Used (ASUSTeK Computer Inc nForce4 AC'97 Audio Controller)
PCIEX4_1 (5h) : PCIe x8 +5V PME Half-Length Available
PCIEX1_1 (6h) : PCIe x2 +5V PME Half-Length Available (ASUSTeK Computer Inc nForce4 Parallel ATA Controller)
PCIEX1_2 (7h) : PCIe x2 +5V PME Half-Length Available (ASUSTeK Computer Inc nForce4 Serial ATA Controller)
Port Connector(s)
PRIMARY IDE : None - ATA / None
SECONDARY IDE : None - ATA / None
FDD : 8251 FIFO - Floppy Disk / None
COM1 : Serial Port 16450 - 9 Pin Dual Inline / DB-9 pin male
LPT1 : Parallel Port ECP/EPP - DB-25 pin female / DB-25 pin female
PS/2 Keyboard : Keyboard - PS/2 / PS/2
PS/2 Mouse : Mouse - PS/2 / PS/2
USB1 : USB - None / None
USB2 : USB - None / None
USB3 : USB - None / None
USB4 : USB - None / None
USB5 : USB - None / None
USB6 : USB - None / None
USB7 : USB - None / None
USB8 : USB - None / None
USB9 : USB - None / None
USB10 : USB - None / None
Line In : Audio - None / None
Line Out - Line Out : Audio - None / Mini-jack
Mic In - Mic In : Audio - None / Mini-jack
Back Surround L/R - Back Surround L/R : Audio - None / Mini-jack
Side Surround L/R - Side Surround L/R : Audio - None / Mini-jack
Center/LFE - Center/LFE : Audio - None / Mini-jack
CD In - CD In : Audio - CD-ROM Sound Input / None
Aux In - Aux In : Audio - CD-ROM Sound Input / None
SPDIF Out - Audio SPDIF Out : Audio - None / None
Front Panel - Front Panel : Audio - None / None
ETHERNET : Network - None / RJ-45
Joystick : Joystick - None / DB-15 pin female
SATA1 : None - ATA / None
SATA2 : None - ATA / None
SATA3 : None - ATA / None
SATA4 : None - ATA / None
MIDI : MIDI - None / DB-15 pin female
CHASSIS : None - None / None
CPU_FAN1 : None - None / None
CHIPSET_FAN1 : None - None / None
PWR_FAN1 : None - None / None
CHA_FAN1 : None - None / None
CHA_FAN2 : None - None / None
Performance Tips
Notice 224 : SMBIOS/DMI information may be inaccurate.
Tip 2511 : Some memory slots are free so the memory can be easily upgraded.
Tip 2 : Double-click tip or press Enter while a tip is selected for more information about the tip.
