- May 22, 2011
- USA
Sounds good. Yeah, I also believe its a hardware issue.
update:
I've successfully secure erased both of my ssd's and I will continue to troubleshoot.
I've installed windows on both ssd's but will continue to try and troubleshoot the Samsung before I swap over to my OCZ.
I will also use a qualified gpu driver instead of beta...
I'll report back later...
I'm almost afraid to write this but since Sunday all has been ok.
I did the secure erase on both ssd's and used qualified AMD driver instead of beta even though the qualified is now going on 4 months without an update.
I have yet to plug in my 2nd SSD, it's currently not plugged in.
Will update later in the week.
Yay, good news!
If the lockups happen when you plug the second SSD back in I would call that drive bad.
Did you get BSOD?
All signs point to the SSD. Have you tried a different SATA cable/port?
^^^This.
Sometimes certain hardware doesn't play well together. Not saying the SSD is bad..........yet. It just might not like the combo of the other SSD and spinner that's in your system. Try it in your lappy. If it works, then you know.
