I am having a problem with random re-boots, which I can't track down. I believe it is a hardware issue and not software.
Here is my Rig:
CPU Intel Core i7-6850K
MB Asus ROG Strix X99 Gaming
GPU EVGA GeForce GTX 1080 8GB FTW Gaming
Cooler Corsair H115i 104.7 CFM Liquid
Boot Samsung 950 PRO 512GB M.2
Memory G.Skill TridentZ Series 32GB (4 x 8GB) DDR4-3200
OS Microsoft Windows 10 Pro 64-bit Ver 1803
PSU EVGA SuperNOVA P2 850W 80+ Platinum Certified
Case Phanteks Enthoo EVOLV ATX ATX Mid Tower Case
A few weeks ago random re-boots started to occur. I performed all the potential fixes memory tests, check disk etc., I've run SFC scannow detecting no missing or corrupted files. Running Webroot SecureAnywhere and routinely run Malwarebytes. I've turned off autorestart in advance windows settings but the problem persists. I updated all my drivers after trying everything else I update to the latest beta firmware for the board. I've been unable to diagnose the problem since no dump file is formed. The event viewer simply says there has been an unexpected shutdown after the fact. The problem is now getting worse it re-boots every 15 minutes while idle. I can track this in the event viewer overnight.
I've tried pinpointing the potential hardware problem by removing 2 of the ram sticks, restarting then replacing and removing the other two and it re-boots in both cases. I reseated the CPU and changed out PSU cable slots where I could and this fix the reboot for a day a day at idle. As soon as I stressed the cpu re-boots started again. Also my 2 additional storage drives disappeared in Windows but visible in the bios. I again re-ran PSU cables to those drives and got them to show-up but re-boots every 14 to 15 minutes continues.
I figure this is either a mobo issue or a PSU issue. Any insights.
Thanks,
cjb4
Here is my Rig:
Thanks,
cjb4
