- Jul 30, 2014
Hi all,
Looking for abit of advice/help here. I have a Android TV stick I am using and I was thinking to use the steam in home streaming after testing this on a laptop and my main desktop machine. Problem I am having is that I can't run the software since the Android OS is lower than android 5.0 so it can't install the steam beta client. I mainly use the stick for Kodi streaming/live tv since the aerial at my place is busted so all my content is online streaming when I do watch.
What I am thinking to do is buy a Raspberry Pi for Retro Pie aswell for the nostolgia, essentially what I want to do is have one Raspberry Pi with Retro Pie installed and then with Android 8.0 installed aswell.
Android - For Kodi/Apk steaming/running the steam apk (my desktop runs an AMD card not keen on parsec since I have seen good results with steam stream).
Retro Pie - For all the console gaming for alot of older stuff (sega master system/mega drive and playstation/psp)
My other option is buying another TV stick which I am not keen to do since it most likely won't get OS updates and im not keen on spending up too much money.
Cheers,
Bandit
- My question is how would I go about having a dual boot install of Android and Retro Pie running?
- Also if I was to install the latest android version would it work properly (ie wifi so I can actually make use of the internet on it) and has anyone already done this themselves and confirm which version is working properly on the Pi.
- My last question is which Raspberry Pi would be the best one to get to do all of this/is Raspberry Pi 2 enough to handle this or do I need Pi 3 if so why? (Try to keep cost down as much as possible)
Cheers,
Bandit
