Hey everyone. A few years ago I was here and I got all your help building my dream computer within my budget. Well, the times have changed and theres better stuff out there. I have money again and am looking to upgrdade.
I will list exactly what I have in this computer, however I am NOT willing to change my Case. I'd also not like to change motherboards unless someone feels it is absolutely necessary. I'm mainly looking at going to ddr3 ram and upping it to 4gigs, also my processor isn't exactly up to par in my opinion. Anyways, any suggestions to improve my current build are much appreciated.
My current budget is $350, and I would really like to not pass that number.
(Note: This computer is used for much multi-tasking in small-end programs, running Dual-monitor dual-screen setup. This computer gets a lot of use. It is also used for med-high end gaming with games like WoW, Rift, SC2, All Call of Duty games, and diablo3 when it's released.)
CURRENT BUILD:
Case:
Thermaltake ArmorPlus(Armor+) VH6000BWS Black Aluminum / Steel ATX Full Tower Computer Case
I love this case, and the size of a full tower is specifically something I did want, I do not care to upgrade my case.
Motherboard:
ASUS M2N-SLI Deluxe AM2 NVIDIA nForce 570 SLI MCP ATX AMD Motherboard
I would really like to avoid changing motherboards because I hear the hastle and problems can be great, especially because I'm afraid my computer won't boot on a different board without re-installing the operating system on the new motherboard (i had that issue a long time ago, I'm not sure if todays technology still has this issue).
Power Supply:
CORSAIR CMPSU-650TX ATX12V / EPS12V 650W Power Supply 100 - 240 V UL, CE, CB, TUV, FCC, CCC
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139005
So far I have no problems with this. I don't see myself needing any more than this unless someone thinks I really need it based on further upgrades.
Video Card:
BFG Tech BFGE88512GTSE GeForce 8800GTS (G92) 512MB 256-bit GDDR3 PCI Express 2.0 x16 HDCP Ready SLI Supported
http://www.newegg.com/Product/Product.aspx?Item=N82E16814143119
I know its a good card, especially with G92. I'm not sure if it's worth going higher than this in today's extreme gaming economy.
Memory/Ram:
Kingston 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 667 (PC2 5300) Dual Channel Kit Desktop Memory
I'd like to go to 4GB, but based on my own research, it seems better to just nix the two sticks I have now and go right to buying 4 sticks (or 2x 2gb sticks) of DDR3. Anyone else recommend this?
If anyone does recommend ram, please make sure its compatible with my motherboard lol
Processor:
AMD Athlon 64 X2 6000+ Windsor 3.0GHz 2 x 1MB L2 Cache Socket AM2 125W Dual-Core
I'm kind of a scrub at researching processers, I know this isn't the best processor, and would really like a recommendation on where to go here. Think I should be headed to quad-cores? Is it affordable?
CURRENT BUILD:
Case:
Motherboard:
Power Supply:
Video Card:
Memory/Ram:
Processor:
