bladerunneruk
- Nov 2, 2012
Hi folks
looks like a friendly informative forum so I just joined !
Please could someone advise on a few points regarding a rebuild of PC,
Current system is : Asus M2N-E, AMD athlon X2, 2x1Tb SATA mirrored drives, 2x500Gb SATA mirrored drives,1x UDMA system drive. OS is XP SP3, need to check power supply, think it was 450W, an nvidia gfx card, an mitsibishi diamondtron crt monitor
Intend to reuse all the drives, reuse the CRT (- it ain't broke yet !), resuse PSU and case, reuse gfx card (single card only). May wish to go twin screen at a later date when CRT dies. Reuse 1394 card. Reuse draftN wifi card, possibly change the main system drive and update to windows 7 but don't really want to shell out the cash.
Usage : Primarily photo editing (not adobe CS) and a small amount of video editing, general surfing & docs etc.
budget about 200GBP +Win7 if needed
apologies in advance if I take a week or so to reply, no access at work, busy at home too !
Query 1 : Can I retain the raid arrays if I buy a mobo with nvidia controller. ? The existing mobo had nvidia raid and was easy to set up raid arrays post XP install and I still have the build notes when I put the system together. Can I retain the raid arrays if I buy a mobo with nvidia controller e.g. M4N98TD http://www.saverstore.com/product/20083297/Asus-M4N98TD-EVO-Socket-AM3-ATX-Motherboard
Query 2 : If I update to windows 7 can I install over top of XP and retain exisitng installed programs ? If not what's best way to migrate them ?
(at back of my mind I might go for a new small (40Gb ish) ssd hdd and an OEM W7 but I don't really want to spend an extra 100 for W7 and 60 for ssd)
Query 3 : CPU : currently thinking about a phenom X4 955 or 965, may do a little overclocking but I'm not going to risk a system or hdd to eke the last Hz. Bulldozers don't seem to be worth the extra £££.
Query 4 : Mobo
I need 6 SATA HDD connectors + 1UDMA or >6 SATAs if using a new ssd hdd. Prefer ATX size. Prefer Asus as found the build straightforward last time (good documentation)
option 1 - M5A78L/USB3
http://www.saverstore.com/product/2...3xPCI1xPCIe-X162xPCIe-X1-IDE6xSATA2-RAID-2xUS
Option 2 : M5A97 PRO (poss when rev 2 arrives)
http://www.scan.co.uk/products/asus...r3-sata-iii-6gb-s-raid-sata-pcie-20-(x16)-atx
Has the faster SATAIII HDD connectors so should be more future proof
Query4a on mobo. Storage requirement is only going to increase and increase, starting to wonder about a NAS, is eSATA needed for a NAS ?
Query 4b on mobo - any alternatives recommended ?
Query 5 : memory - what's fastest the mobo&cpu can actually use in practice (I see some asus website comments on mobos about 1333 being max amd 100 series cpu can do ??) I don't eant to pay out for faster memory and then find it can't be used.
Thanks for reading and for any advice whichs comes my way
And sorry to disappoint all the gamers out there (I used to play avidly N64, xbox etc, but don't have the time now, hence the late post !)
Query 4 : Mobo
