- Jan 12, 2013
desktop rebuild
so right now here are the spec's for my current rig
Fractal Design R3
2x 120mm front intake
1x 120 mm rear exhaust fans
(not installed yet)
1 side intake and 2 top 120mm exhaust fans
Sabertooth x79
i7-3820e overclocked 4.5ghz (Akasa Venom CPU cooler)
32gb of g.skill z ram
2x radeaon 7970
1200watt psu
2x 256 ocz vector 4's
2x 120gb ocz vector 3
1x 3tb western digital black edition
1x lg blurry player
3x 3tb external usb 3.0 drives
so im having a lot of problems with heat. so i started to check my clock speeds, took it down a notch down to 4.5 its running at now which isn't giving me any cpu issues but the problem lies in the vcore and the heat generated by the south bridge blows air right onto other overheat components which my temp graph shows as the "motherboard" for what its worth.
so my first step to go back to stock clock speeds which made almost no difference, still lots of artifacting and low frame rates. next i tried disabling the crossfire and that seamed to have fixed the issues a little, at least for far cry 3 but its still running very hot under load.
it seams that one of my next option is to water cool everything.
so i was thinking that my case may not be up to task of supporting extreme water-cooling and deal with more internal storage options.
my thought it todo a double radiator system. and probably do 2 loops. one for the GPU cards and the second to handle the MOBO and CPU
right now i was looking at a case-labs case probably a Magnum TH10
so the question are as follows
what other cases should i look at?
i think the motherboard is holding everything else back? if so when would the next wave of MOBO hit the market? asus put the sabertooth out around this time last year
lastly i think i might need as much as 20TB of storage (part of why i selected the case i did) which sata cards would make the most sense?
Fractal Design R3
(not installed yet)
Sabertooth x79
2x radeaon 7970
1200watt psu
1x lg blurry player
