johndavies11223
- Jun 5, 2018
Hi Folks,
I have bought a 2700x and am looking for some fast 32GB memory to go with it. 3200 speed would be nice.
I have read so many discussion forums and reviews and still do not know which kit to get. It seems some people say that it is hit and miss and you need a specific kit - i.e. Flare. Others say most of the ram issues are in the past and any memory rated for 3200 would be fine.
I have shortlisted down to:
G.SKILL TridentZ Series 32GB (2 x 16GB) 288-Pin DDR4 SDRAM DDR4 3200 (PC4 25600) Desktop Memory Model F4-3200C14D-32GTZ - has lots of reviews on newegg including from people who say it works fine with 2700x
G.SKILL TridentZ Series 32GB (2 x 16GB) 288-Pin DDR4 SDRAM DDR4 3200 (PC4 25600) Intel Z170 Platform Desktop Memory Model F4-3200C14D-32GTZSW - not really sure what the difference is to the one above apart from it is more geared towards intel?
G.SKILL Flare X Series 32GB (4 x 8GB) 288-Pin DDR4 SDRAM DDR4 3200 (PC4 25600) Desktop Memory Model F4-3200C14Q-32GFX - 4 sticks and only 2 reviews... but it flare which is supposed to be built for Ryzen?
G.SKILL Ripjaws V Series 32GB (2 x 16GB) 288-Pin DDR4 SDRAM DDR4 3200 (PC4 25600) Desktop Memory Model F4-3200C14D-32GVK - Plently of reviews also including people who say it works at 3200 with ryzen
I don't care about RGB at all - just want the most stable, quality ram i can get that will run for 5 years.
In terms of motherboards... all the ones i have looked at for ASUS and AsRock in the x470x category do not seem to have any of these on the QVL list. Any particular board anyone would recommend (with 2xm2 slots)
Which Ram Kit would you recommend getting? (feel free to also suggest a different kit!)
cheers
cheers
