Well, technically, once I get the new CPU/Mobo/RAM I have enough components for 2 PC's, but the focus is only on the new high end system yes. I'm still thinking it over but I'll end up flipping a coin tomorrow morning. I'll post back with what I've gone with, and I'll probably post my RAM choice for scrutiny before pulling the trigger actually.
I've actually already bought a Bitfenix Prodigy M, but I'm planning on OCing my FX-8350 on the side, so I'm thinking maybe my current FX-8350 CPU will be moved to the Bitfenix M for the better cooling. (2x 120mm sock fans, 1x 140mm rear fan, and 1x 230mm bottom fan, for which oddly there is no dust filter). Though nothing is certain yet, It's likely that the new Intel system will go into my current Silverstone Temjin TJ08B-E mATX case.
Though the Raijintek Metis case is fairly inexpensive if I still wanted a mini build, I think attempting to stick an OCed 6700k + my current 980Ti into it might be impractical, even with the big side fan case mod I was planning to do with it. What do you think? I'm not apposed to case mods, my current full sized motherboard sits in a mATX case right now, and if I decide it's going into the Bitfenix Prodigy M... it is.
I couldn't consider the Hadron Air because I'm using an existing ATX PSU and I don't know what case modding would allow me to get it in there. Maybe up front where the hard drive racks are. But the glass window takes away some of the portability appeal of going mini, since now I would be nervous to just throw this thing into a suit case or something, I'd need to give it similar consideration to a mATX case.
