- Jul 14, 2003
So i've been wanting to do a cheap custom loop for a while but have been waiting for a certain CPU to come my way (Xeon E5-1650v2). Its on its way finally, so now im looking at this again. However, ive worked around custom loops but consider myself a custom loop noob still, so forgive me for some of these questions if you can. Additionally, i want to do it as a proof of concept of sorts for youtube content. Initial research (from here even) had me looking at using Barrow/Byski fittings. I'm trying to get the best pump/res for the least money and a recent release from Alphacool repeatedly has caught my eye, and that is the Eisstation. The one that includes their D5 pump in it is $100 though and i was hoping to go more budget than that. They dont have one that includes the DDC pump, otherwise id likely go with that but they DO have one that includes their DC-LT Ultra 2600 pump for less than $50 total. Thats this link here: http://www.performance-pcs.com/alph...tra-incl-alphacool-dc-lt-2600-ultra-pump.html
I think this is the specific pump page:
http://www.performance-pcs.com/alph...-low-noise-ceramic-12v-dc.html#Specifications
I'd also like to include my 980ti in the loop but i don't have a block for it, and for the most part they seem pretty expensive. Its an EVGA 980ti SC+ model which from my understanding uses the reference PCB i think, so WBs for the Titan X (maxwell) also fit. Are there decent cheap blocks around as well?
The tubing i'd like to use is Mayhem's most likely, but the thicker OD stuff. I think it looks alot nicer (on top of being more kink resistant as well). Though the exact size eludes me. What is it specifically that is recommended given that info?
For the CPU block i had another idea. A couple of tech youtubers i follow featured this block and it seemed to perform well (OztalksHW and Jayz
Here is jay's vid on it:
This is the block:
https://www.amazon.com/Water-Coolin...013JD2CVO/ref=cm_cr_arp_d_product_top?ie=UTF8
Whats weird is that page says socket 2011 compatibility, but the page for the black version of the same block doesn't. Strange. Anyways, im open to any and all CPU block recommendations as well.
For fluid i was just hoping to go somewhat minimal, for minimal maintenance. No pastels. Some clear fluid with maybe a little dye for some color but thats it. Maybe even UV. Any recommendations for that? I would think a drain valve might also be something nice to include, hopefully byski/barrow have something.
Radiators...well i know to go for copper. I know Black Ice is top notch. But i dont know whats best for the money. Im thinking a 360mm rad should be enough hopefully. Probably something a bit thicker than 30mm i imagine as well. Completely open to recommendations there. The case im using is a Raidmax Sigma. Heres how it looks with and without gear inside it:
Almost forgot to mention fans. I'd want the best i can for the money obviously, but im not sure if NF-F12s are in the budget. I like the Deepcool TF-12s on my Captain 240ex, but im not sure how they stack up. Any recommendations there as well?
So thats where im at. I'll continue researching what i can but i appreciate any helpful information from y'all! Thanks in advance!
This is the block:
