SUCCESS on build / startup
This posting is from the new Haswell build, up and running!!
Couple of questions near the bottom, following a brief review of process...
The build took about 2 hours owing to mechanical confirmations, couple of mobo mounting spacers added, and just making sure the cpu / heat sink all fitted up secure, followed by sequential device install / startups to get the OS installed and then letting the OS identify peripherals as they were added, in case there were any complications. Gladly, none were found and the startup went as expected. The heat sink fan came with an alternate set of install brackets to reverse which side of the sink the fan mounts to. The alternate was selected to make sure air flow was pulling fresh air across the RAM chips and setting forced output to exit the back of the PC, matching the power supply air flow direction etc.
The tech that assisted in the build has decades of digital engineering experience and being an Asus fan took note of several features the ASRock mobo came with out of the box, remarking a full featured product for the price. Asus may lose a customer on that point. (grin).
I bumped the SSD up to the pro version just as a measure of better reviews but aside from this change in the spec, the only complication with Newegg was an ultra high temp thermal compound that ended up having to ship from Asia, so we installed using the compound that came with the CPU heat sink.
The Win10 install from thumb drive went flawless and took a whopping 20 minutes at most using a keyed install with the OS key provided. Updates backgrounded from auto sensed cable network hard wired Ethernet over the next 30 minutes or so. A couple of restarts were needed to get drivers fully integrated, but no manual driver installs were required.
The 960 Nvidia graphics card did in fact permit 3 monitors to go active straight away on two DVI-D and DVI-I connectors + the HDMI to DVI cable, no converters or passives were required but simple patch cables. All monitors report HD graphics and the 960 showed full 3D capability are present on all. When I first added the third monitor on the HDMI port I found a warning appeared a few minutes later indicating I was running low on RAM (16 Gig). I didn't chase it down but restarted just to be sure the OS could re-acquire any changes for the HDMI. The warning has not returned since.
Win10 is still pretty foreign to me so there's the usual discovery and hunting process to learn the how-to's and get fluid with doing things, but CPU-Z and CPUID HWMonitor both installed and came up with nothing that raised any immediate concerns, other than I'm not sure what would be expected on nominal values if they're reasonably nominal or not. Fan's are completely silent at this point and responses to benching reported 100% for the 4790K standard so it seems baseline didn't trip any issues. In fact the thing runs so damn cool it's almost as if it's not even plugged in. LOL The cheap project case came with only a 2 wire fan if there were any disappointments at all, but for some 27.00 bucks I can spring for a better fan once I know how well cooling sustains under load if it presents any issue later.
Questions:
1. Being a new build, is there a link here that suggests a detailed startup benching or other inventory documentation procedures for new startups? There is a lot of data here and I won't pretend to know what all the values SHOULD read at idle or especially under a known demand if there is a formatted testing process that can be referred? Obviously I don't want to just start jamming gears and tear up a new build, so for now I've just keyed in a few short stress test processes to cycle some heat up and down on the devices and let the heat compounds normalize over a little time since Friday night startup.
2. As baseline or any inventory is completed I should have installed the target application by later today, so the next question is
how to proceed to working up the OC profile and if there's a guide for the OC process here, or do we do a hand-holding thing to make sure I don't blow out the new toy by stupidity?
I guess that's it for now short of
continued and huge appreciation for all the help and that the startup came off
without a hitch.
Materials cost came to about 1480.00 USD including the project tower case, the OS at 200.00, a touch sense Logitech wireless keyboard and dual battery Logitech wireless mouse, plus the SSD upgrade, 3 patch cables and a cheap portable DVD burner in case any media installs were needed. In all the cost is well contained to budget on the bang-for-buck factor.
Newegg's delivery was roughly 48 hours, single shipment to Michigan with the special thermal compound being the only mis-fire on delivery out of Asia.
I might just run it through the car wash this afternoon, park it and shine the rims in public so all the other PC's can drool some.
Cold starts take about 7-9 seconds and shut down is like 2 seconds flat. This thing absolutely flies Win 10 on typical browser and other desktop activities, mostly a sense of being nearly instantaneous by dual core Win 7 standards.
Mike
