Oh no! Lightening strike kills mobo
Hi,
Thread is revisited to see if there are recommendations on finding a replacement MOBO.
The machine's hard wire network saw a lightening surge extreme exposure.
SSD drive survived, backup data retained.
The machine still worked on alternate network interface but soon complained of USB requiring too much power drain.
Board now fails to run after post reaches F11 boot menu.
The setup page shows only for a split second when board shuts down.
Each attempt to restart requires the power supply switch to cycle while holding start button in.
CMOS was cleared, RAM swapped and relocated, no joy.
All peripherals removed, Debug codes appear to complete until setup page.
It's assumed this is a power supply crow bar else debug should have more indication.
An alternate power supply behaved exactly the same.
Build was from suggestions here on posting 17.
https://www.overclockers.com/forums...ns-to-budget?p=7847333&viewfull=1#post7847333
The MOBO used was Newegg ASRock Z97 Extreme6 LGA 1150 Intel Z97 HDMI SATA 6Gb/s USB 3.0 ATX
This MOBO appears to be out of production now and little luck finding a replacement.
Hoping to hear if anyone knows of a working board for sale or can recommend an alternate MOBO for the Intel i7 4790K?
This system worked remarkably well / solid for some 2 plus years.
Much appreciation for suggestions if anyone should pick up this older thread.
Regards,
Mike
