- Dec 14, 2004
- Charlotte, NC
So I have 5 120mm (3 on my rad) and 2 92mm case fans plugged into my fan controller. The ones I have now are LED (cool at first, now annoying when I sleep) and I think kinda crappy.
I planned on buying 5x 120mm high speed Yate Loons. I figure they'll be loud and effective at full bore but I can run them at 50% for normal usage. Is there a better fan for that use or is that a good choice? I found them for $3.85 each so that's definitely a plus.
I couldn't find any Yate Loon 92mm fans so I have no idea what to get for that. I'd like something that works in a similar way (screemer at high RPM but works well with a controller) if possible. Any suggestions that are on the cheaper side?
EDIT: I'm also thinking about getting a MCP320 rad to replace my current BIXIII. Should I get the high density rad to go with the high speed Yate Loons or stick with the QP low density version?
