- Dec 20, 2011
I imagine the moderator is tired of this topic but I would still like to put in my two cents worth.
First off, if you live north of the Mason-Dixon line just move your box, monitor, keyboard and mouse out to your garage or patio or whatever you have and run your own no cost low ambient temperature overclocking and cooling experiment.
But if you have a garage, some basic cutting tools, the use of a pickup, and about two hundred dollars to waste you can do a much more elegant experiment.
Here is what you would need...
Used deep freeze from your local used appliance dealer
300 pounds of free weights from a garage sale
some velcro strips from the Dollar Store
an accurate thermometer, which you get also get at Dollar Store
a mixing bowl
five pounds of plain old rice from the bottom shelf at the market
cheapo usb hub would be helpful
When you get your used deep freeze situated in your garage put in 300 pounds of iron weights as a huge heat sink and the bowl of rice to absorb moisture.
Take your computer apart. Put the motherboard and video card in the deep freeze. Cut one of more holes in the side of the deep freeze big enough for your cable. The 24 pin connector from the power supply will determine the size of the hole. Use the velcro to stick your power supply and hard drive and optical drive to the side of the deep freeze so that the cable will fit.
a mixing bowl
