- Aug 10, 2010
- Sunshine State
@ SupaMonkey
From personal experience with rubbing alcohol...
OEM TIM --> The stuff that comes with the stock heatsinks for the cpu and also on the heatsinks on the motherboards --> This stuff is almost always baked on and will require lots of work to get it completely off the surface, especially the one they use on the Gigabyte motherboards for the northbridge and southbridge chips.
Arctic Silver 5 --> Cleans right off with just a bit of elbow grease.
Shin Etsu G751 --> Cleans right off with very little effort.
Thermalright Chill Factor 3 --> Cleans right off with very little effort.
IC Diamond --> This stuff is thick and will need a bit of work to get it all off the chip regardless of what cleaning product is used.
Ceramique --> This comes right off; all that is needed is to put a drop of alcohol, or Arctic Clean on it and let it dissolve for a few seconds.
So basically all TIMs will require you to do a bit of work... But it's not so hard that it requires any special skills.
