- May 19, 2006
- Where angels carry savage weapons
I'm looking to replace or upgrade my laptops motherboard. Any advice on what the various form factors or standards (if any) for laptop boards? And if there are such standards, does anyone know of any online retailers?
I have a laptop from iBuyPower, that is just under a year and a half old. Warranty is expired. The problem with it is the USB ports stop functioning after the thing heats up a bit. I believe I fragged it awhile back when I ran Oblivion on it for several hours. Now, if I were to run any program to make it heat up, or if it has been on for ~20 minutes or so, the USB mouse will fail and windows will prompt malfunctioning hardware for every USB device I plug into it.
