btw the link doesn't work for me. How does recapping work?
does it revive old electronics already blown or leaked caps(doubtful) or is it meant for preventative maintenance.
I had a psu blow once and some caps on a very old motherboard running like duron 500 mhz at the same time. or was it just the board.
I also read on a newegg motherboard page about japanese caps having 50 000 hours of mtbf, so does that mean we should recapp our stuff after 5.78 years (24/7use)?
and it will most likely keep kicking if we didn't heat damage or do anything else to them?
The link worked for me, but the web page always made IE8 lock up. However it was OK with Firefox.
In my very limited experience, when devices quit working due to bad capacitors, replacing only those capacitors usually make the device work normally again, but sometimes the power transistors that feed current to those capacitors also fail, as one did on my old Socket 7 mobo. That's not to say you should replace only the bad caps, because all the other caps identical to them (same brand, type, capacitance, voltage) and that serve the same function (i.e. CPU voltage regulator, memory voltage regulator, video slot voltage regulator, or bypass filters) have been exposed to the same conditions and are likely just as worn. Many experts recommending replacing all the identical caps, wherever they are on the circuit board.
Some higher priced mobos are made with nothing but high quality caps (solid, AKA poly or os-con -- I've never seen a retail mobo made with regular electrolytics that were all Japanese or Samxon) and seem to cost as little as $75, but most mobos use 2-3 grades of quality, with the best brand installed around the CPU, the worst spread around for bypass.
MTBF isn't necessarily closely related to average lifespan because MTBF assumes that the devices don't age. That may be why hard drives made back in the 1980s had expected lifespans and MTBFs of 30,000-50,000 hours while HDs made now have MTBFs of over a million hours, but expected lifespans are still about the same. Also good and bad capacitor manufacturers both seem to specify about the same lifespan ratings, but the bad brands routinely fail ten times faster.
I wouldn't wait 5.78 years to change caps because:
1) Good caps will probably last that long without problems. For example, if rated for 2,000 hours @ 105°C and operated at 60°C, expected lifespan is
2000 hours * 2^[(105°C - 60°C)/10]/(8766 hours per year) = 5.16 years.
But cut the temp another 5°C, and expected lifespan increases by two years.
2) Bad caps in any voltage regulator circuit or next to a hot chip shouldn't be trusted beyond 1-3 years. I've had OST brand caps on ECS mobos and Fuhjyyu brand caps in old Antec PSUs bulge or pop in as little as 1-2 years. OTOH my Delta PSUs, made in 1999 with only Chemicon, Rubycon and Nichicon electrolytic caps, are still working fine, and their caps look good (sampled a few, no high ESR), and my 33-year-old TV, made by Sanyo with only Sanyo electrolytic caps, has lost only two of caps, although a non-Sanyo replacement for one of them had to be replaced.
What I do with my own stuff is leave it as-is during the warranty or return period or a year, whichever is longer, and then replace any less reputable brands of caps with good ones. I'm no expert, but I don't think this is necessary for the bypass caps that look OK (no bulging, leakage, or corrosion) and are located away from heat because I've yet to find any that measured bad for ESR or capacitance (Ltec/Luminous Town Chinese caps, OST Taiwanese).
