MechaTech84
- Jun 23, 2012
First things first, I read the beginners guide here, and a few on other forums as well. I have done a lot of research, and have finally gotten around to choosing parts. All the parts I selected are Copper as far as I can tell, although the fittings are brass, which if I remember correctly should be fine. I went with compression fittings because they seem easier secure correctly, and they are recommended by all the guides I read.
I am requesting that someone double check my parts list to see if I missed anything or if there will be any issues with what I've chosen. Currently I am only concerned with a single loop to cool the CPU.
My Rig:
Chassis - CM Storm Trooper
Motherboard - MSI 890FXA-GD70 (Included just in case)
CPU - AMD Phenom II X6 1090T (AM3 Socket)
Parts:
Coolant - Distilled water (I won't be buying this online, so no link)
Biocide/additives -PT Nuke PHN
Reservoir - XSPC Dual Bay Reservoir for Laing D5
Pump - Swiftech MCP655 Watercooling Pump - w/ Speed Controller
CPU Block - XSPC Raystorm Mounting Kit for AMD AM2 / AM3 Processors
Radiator - XSPC RS240 - 2x120mm Dual Fan Radiator
Fittings - Bitspower Matt Black 1/2in. Compression Fittings for 3/4in. OD Tubing (x6)
Tubing - Tygon R3400 1/2in. ID 3/4in. OD (8ft)
Did I get enough fittings, are they the right kind? Am I overbuying on tubing, should I be overbuying on tubing for ease of setup? If I wanted to expand in the future to watercool my GPU I would either have to run two loops or buy a different CPU block, right?
My Rig:
Parts:
