- Sep 13, 2015
Just a FYI most appts I have worked in here come from main service pnl to a tap box than branch out to a stack of meter base's . Never seen a pass through system Like you were talking about .
Most apartments here follow a similar multi meter approach but I have worked at a few complexes that focused on short term furnished leases that had all utilities included. In this instance w occasionally ran into a setup where a would have lugs on the bottom and the top of the bus and the panels would be daisy chained to each other feeding into the bottom of the first floor apartment and then out of the top of the first floor into the bottom of the second floor and so forth. Never really limited these systems as you ended up killing a whole block of apartments if you needed to kill the mains as there was no individual shut off for each apartment.
