- Dec 27, 2008
Yes, its haswell compatible....... both.
If you learned anything here is that it doesn't matter much (haswell compatible)... keep your head out of the minutia and grab one of those two linked.
It's fine.Sorry... what card do you have? A 650ti plus that system you listed? Man, you won't be breaking 250W.. the 450w is fine if you like. Maybe see if the evga 500b fits your budget.
For EVGA 450B, cause of PC case that I use, I want semi-modular or full modular, at least 80 Plus Bronze, cause I can't offered to have cables in ITX PC Case, which I should have mentioned from the beginning that I have ITX/mini-ITX case that is this: Cooler Master Elite 120 Advanced.Your card running full tilt is 140W Max. Usually it will be less than what it's rated when gaming. Your cpu is a 45W dual core when it's fully loaded. Add in the rest, say 50W, you won't be breaking 250W. 450b is plenty for this build if you want.
REALLY?I said 450B in my last post, not 500.
So NOW you say you want modular, lol, ok! Just in case you missed it, that 750w corsair isn't modular either. Yeah, you'd want modular in that thing. Not sure if frys has any psus in your budget that are modular that are worth it...I can't believe $4 is going to crumble a build costing $600. Pack lunch twice.. done!
That PSU is sold out, according to website.Cx750m would be my guess...and I don't see it there. Look for a lesser wattage CX series psu. But if you hit $80... I'd go for the much higher quality unit in the 550 g2 (it's modular).
Uhh.... No, it isn't my first build, I have building for long time and my College Major was Computer Network Electronics Technology. So, I have built my PC for plenty of times.Yeah, that Antec should do you just fine. Antec has a been around for a long time and is a reputable PSU mfg. If you are using one of those small cube cases you really do want a modular PSU. You will get better air flow.
Dude, you are obsessing over all this. Must be your first build.
* 1x Thermaltake Core X9 (CA-1D8-00F1WN-00)
* 1x Corsair RM Series RM850 PSU
* 1x Intel Core i5-4690 Processor (6M Cache, 3.5 GHz, up to 3.90 GHz)
* 1x Asus Z97-PRO (Wi-Fi AC) Motherboard
* 1x Corsair CMX8GX3M2A1600C9 8G (2x4G) DDR3-1600 Memory (Fry’s Electronics)
* 1x Intel HD Graphics 4600 (Came with CPU)
* 1x ASUS STRIX-GTX970-DC2OC-4GD5 GeForce GTX 970 4GB 256-Bit GDDR5
* 1x Samsung 850 Pro Series MZ-7KE1T0BW 2.5" 1TB SATA III Internal SSD
* 1x Seagate ST31500341AS 3.5" 7200.11 1.5TB SATA300 32MB 7200rpm
Oh, ok.It isnt haswell certified as is your requirement (though, I wouldn't worry about it...worst case disable the deep c states).
If only, " EVGA SuperNOVA 550 G2 Power Supply" hasn't been sold out, I would have decide to over spend $3 USD or more...Lol, you really dont.. but whatevs...
